Thread: thick coatings
Old 09-05-2006, 09:50 AM
sswee's Avatar
sswee sswee is offline
Moderator
Default Re: thick coatings
Originally Posted by mh
running 3 to 1
Good
6xxx series alloy
Best
68 to 70 degrees tank temp
58 to 60 degrees
if 720 applies then does that mean for a 3 mil coating at 12 ASF then tank time will be 180 mins.
Yes, running at 8ASF, I've had runs up to 240 and 270 minutes
by extreme agitation do mean mean like wildly boiling water??
Close but but by the time I got to that stage of anodizing, I had started to use a pump to circulate the electrolyte. It has a fast flow in the tank without the misting problems of aeration.
Here you can see my setups. I started using a pump on the 20 gal.
http://forum.caswellplating.com/phot...ry.php/cat/510
For your use of the parts, you'll have the most success by getting the tank temp down and improving circulation. By doing this, the pore size of the coating will be smaller and give a more durable coating. The parts will have a gold to golden brown hue to them and you should be able to use a 1.5 to 2 mil coating for the same end results.
SS
