Re: thick coatings
your 60 gallon tank is the best setup i have seen yet. brilliant.
can i ask what size power supply u use for it as i am using a 20 gallon tank with a 30 volt, 20 amp power supply and the other day i was doing a piece of cast that was 103 square inches and my voltage rose right up to 24volts at one point.
will i need a higher voltage range when i upgrade to the bigger tank?
also, can u regulate the flow coming out of ur pump as to change the agitation levels. if so how?
hope u dont mind but i am going to copy ur setup right down to the colour of ur hose clamps!!!!!!!!
