Re: thick coatings
so all the agitation is directed from one end of your tank. in the pics of your 20 gallon tank it looks like u have run a length of pve with holes drilled in it much the same as the system i am using now with an air pump.
did u find the fluid shooting out the pvc setup gave u a more uniform agitation from all points of the tank?
r u able to disconnect ur chiller, by the looks of ur connections u can unplug and reroute straight from pump back to tank...great idea!!! do u always run with chiller or only on large runs??
