Old 09-07-2006, 02:18 PM
sdold's Avatar
sdold sdold is offline
sdold is on a distinguished road
Default Re: Business Website
If you like learning code but want the software to "help" a little, check out the free edition of 1stpage. It's awesome.
Home and Main Page should be one page, just "Home". The splash page shouldn't be the home page.
Some pics are out of focus or not lit well. Use force-flash or have the sun behind you when taking pictures.
Most of the pictures of the quads are great, especially on the splash page.
There are some grammatical and spelling errors. I'd get two or three people to proofread it for you and try to make it sound professional. How about something like this:
Welcome to the Temperance Coatings website. We are a small shop specializing in personalized, quality custom powdercoating work. We are usually much cheaper than the larger shops because they must carry significant overhead and typically aren't set up to do smaller jobs efficiently. We specialize in coating quad and dirt-bike parts, but can also do car parts, furniture, mailboxes, bicycle frames, tools, or just about any other metal part that is able to withstand the 375-400 degree curing temperatures. We have a wide color selection available with many different "looks" available ranging from simple single-color finishes to unusual textures, candies and metallics. We have coatings that look like polished aluminum, and some even approach the look of highly polished chrome.
Powdercoating begins as a fine powder that is applied to the part with with a special gun. As it leaves the gun, it is electrically charged, causing it to cling to the part. The part is then moved to an oven and cured at around 375 to 400 degrees for about 15 minutes. This melts the powder and fuses it to the part for a beautiful, long-lasting finish that is highly durable and chip-resistant.
We invite you to look through our gallery and see for yourself how ....
blah blah blah, you get the idea
Steve Dold
http://stevedold.com
