  #8 (permalink)
Old 09-09-2006, 12:56 AM
sswee's Avatar
sswee sswee is offline
Moderator
Default Re: Agitation purpose???
How many outlets do you have?
You can restrict the outlet on the pump just don't restrict the intake. If you restrict the outlet right on the end you can boost the pressure, giving better agitation. Kind of like sticking your thumb over the end of a garden hose. The more outlets you have, the more you'll need to restrict each one. If not you'll end up with good volume which is good for cooling but not the pressure for the agitation.
What size inlet and outlet does your pump have? Mine has 3/4" in and 1/2" out.
SS
