Re: Stickey triger
remove the trigger then remove the nut that holds the trigger in place now slowly pull the plunger out and clean it and the hole it goes in. Put just a dab of vaseline on the rubber O ring and re assemble work the triger back and forth if it still sticks then you did not get it clean enough.
Jason
