Old 09-23-2006, 06:51 AM
Banditperformance Banditperformance is offline
Default Re: what to use for switch help quickly please
Is your thermostat acctually able to switch 50 amps Are you asking what kind of MAIN off/on switch to use? If you have a rated Tstat to do the job, then just use the sircut breaker that feeds the oven? That's what I do. Or else, you can have a remote 60 amp switch installed, but there pretty pricy.
But, in reality, if you have a control device controlling the high heating current, and your htermostat runs off 120Volt(like contactors do) then you just need a light switch to supply the T stat voltage that will, in turn controll the contactor to heat the elements.
Home ranges are usually rated for 30 amps
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
