Re: Sanding the hard spots.
68commando, chcustom
A few of things to try: first would be a Razor edged buff which is 1/8" thick by 4" diameter. Second you can try 1/8" wide buffs in a 1" to 2" diameter, either treated or untreated. You can use these with greaseless or for buffing compound. Third they make cartridge rolls in 1/4" diameter in different grits that will work real well. You will have to get a different mandrel to use these because of their diameter. And along with what sswee states the Cratex will work also.
John
