Re: Need to plate a 55 gal Steel Drum - Suggestions Needed!!!
Another way to get a gold finish would be to invert he drum over a propane burner, like you cook a turkey broiler with.
Powder coat the drum outside with Mayan Gold powder, then light the burner to heat the drum's inside. Crazy? More than likely, but it MIGHT work. The finish would be quite reasonable, I think.
Do it out of doors.
