Old 10-02-2006, 11:01 PM
sswee's Avatar
sswee sswee is offline
Moderator
Default Re: Newbie setup questions
The problem is that the kit and the instructions have undergone several upgrades and changes in the last year. They are not completely in sync. You should call Caswell or file a PRS. Let them know the problem. To get by for now use the thermostat on the deox and dye at 110*, after putting the parts through deox unplug that heater and adjust the temp to 140*. The dye should be ready by the end of the run. Unless it's below 60*, you won't need the heater in the ano tank. You'll need two heaters / no thermostat in the sealer.
I can't say about the cage on the pump. I don't think it would matter but I'm not familiar with that setup.
SS
