oven
Dale,
At this time I do not have any of the parts, just getting info. Do you use standard oven elements or industrial tubular heating elements? Let me ask a question about your wiring set-up. You run all your elements in a parallel circuit to a solid-state relay, then the relay is hooked to a 220V line, your relay is hooked into the temp controller. Is that just about it or am I missing something. I have the frame down and a good idea about the wiring. Once more thanks a lot for the info. Sure did not want to spend $8000.00 for a oven.
