Thread: I don't get it
Old 10-08-2006, 09:33 PM
acidrain acidrain is offline
Default Re: I don't get it
How about temperature and agitation?
Yes, with 6xxx alloy, the volts should go up, but remember, the lower the temperature, the higher the volts (and vise-versa). As the temperature rises, the volts will go down. Try to keep the temperature between 68F and 70F, and use good agitation.
Are you taking notes?
I always chart the progress of each run.
Write down your start and end times, along with the calculated amps.
Note the temperature and volts at regular intervals: start, 15min, 30min, 45min, etc.
It will help you a lot when trying to diagnose problems.
