Originally Posted by sslayden
Should I be using some other pattern such as alternating 90 deg? I've been polishing it for quite a while, too  Any ideas?
yes when possible you should alternate at 90 degree angles on each step of polish work. this will help show you where you need more cutting if needed and break the pattern/ wave lines.
