Re: 2 Element Oven
well bro that has no easy answer. the elements from the old oven could range between 1500-2500 watts each. if they are the 2500 size and calculating for good tight constructions and minimal or no leaks then the largest i would go is 3x3x6high. this requires 4750 watts to raise the oven 400 degrees.
