Old 10-09-2006, 04:59 PM
alabama_lowlife alabama_lowlife is offline
alabama_lowlife will become famous soon enough
Default Re: newbie in polishing aluminum
you should get some aircraft stripper to strip off the clear coat unless it is anodized, in which case you'll need some easy-off oven cleaner to strip. in order to keep a maintenance free shine, you can reclear or use zoopseal. caswell sells a clear coat that is safe for high temp applications.
