Re: 2 Element Oven
in a near perfect oven it would take only 2100 watts that would work fine with the 2 you have. in a good oven with average insulation and leaks it takes about 4200 watts. you should still be ok. this is assuming you mean 2 square and 4 high. with a 2x4x2high it takes less. when building an oven if you can design it to be long instead of tall it takes less to heat it. just a fyi.
