Re: 2 Element Oven
That's for the info. I was originally thinking making it 4 long and only 2 high, but then was thinking of making it taller to use less space, but in all actuality it wouldn't weight much so i could always just stand it up when not in use.
That's actually good to know about horizontal using less heat because I was planning on the making the larger overn 4x4x8 with 8 foot being the length. Originally the reason behind that was because it'll mostly be used for motorcycle frames and I though it'd be easier to load them if the oven sat horizontally, now I'm killing two birds with one stove so to speak.
