Old 10-17-2006, 03:46 PM
upncoming's Avatar
upncoming upncoming is offline
upncoming
Send a message via AIM to upncoming Send a message via Yahoo to upncoming
Default Re: graying after clear over black..
i will try the 275 for 10
Originally Posted by bzer1
There are several things that could have gone wrong.
1. Over cure on one piece(most likely)
2. Not enough powder(potentially)
3. Blooming on one piece(least likely)
If I were to hazard a guess I'd have to say that it's most likely over cure. You might have a hot spot in your oven or the clear might be curing too fast. I've had problems in the past with milky clear coats. It turned out that most clears are low cure formulas. You might want to lower your cure temp a bit and your dwell as well. you might also let your oven temp drop below your cure temp...say 100* and put your parts in at something like 225* and cure at 325*, the check them at about the 10 min mark. I currently have 10 lbs of clear that has a cure temp of 275* for 10 mins. It will have significant over cure problems if I try to cure at 300*.
D.I.L.U.S.I.
Drive It Like You Stole It
