motor speed
HP has nothing to do with RPM. There are only a few different motor speeds(1750 & 3450 that I can think of right now) but lots of different HP ratings. Higher HP means it will take more load to slow it down. If you need higher speed you need to use a bench mandrel with different size pulleys on the motor shaft and spindle.
1966 Impala (hers)
1966 Impala SS 427 (his)
See them at
The Watering Hole
