Re: cheap excellent material for oven walls
I would caution you on one thing when using the backerboard. This is a compressed fiber product which means that it will create it's own dust. I would suggest sealing the surface to make sure that loose fibers don't get into you freshly coated parts. Personally I would be tempted to use ceramic to coat it as that will hold up to repeated heat cycles without a problem.
