temp controler pain in butt
hi all
i have built an oven with inside dimensions of 36in wide x 64in deep x 68in tall i have 4 2600w burners inside. i have had a heating & cooling co confirm the wiring is correct. i purchased the controller from drills12 on e-bay. some people on this forum have also got the same controler. my problem is that i do not get accurate readings from this set up. the controller reads celsius and i have a conversion chart. my problem is that at 95c on controller i am at 390f in the oven when i should be around 200f. i hang grill thermometers in oven with parts as well as check part temp with laser thermometer to verify oven temp so i have a good idea what the inside temp really is. when i first fired this thing up i wanted to run up to 450f so i set the dig controller to
210c and oh my god it looked like there was an explosion inside the walls warped up horribly. thank god they went back to original shape. found out it got hot enough in there to roast a turkey. i was at 680f. i have sent numerouse e-mails to drills12 and he plays VERRY DUMB. ive come to the conclusion that i am stuck. now i am wondering if anyone else has had the same problem and if so how was it cured. or if anyone might have any ideas as how to fix this or any suggestions on better more reliable controlls for this set up.
thank you
ron
