Thread: Stickey triger
  #9 (permalink)
Old 10-20-2006, 09:48 PM
chromeitout's Avatar
chromeitout chromeitout is offline
chromeitout is an unknown quantity at this point
Default Re: Stickey triger
Quick note... I tried cleaning the trigger mechanism and lubricating as stated above and it did help alot, but after several uses it started to stick again. The last time I took it apart to repeat the cleaning/lubricating I took the spring out and noticed how wimpy it was, so I stretched it about 1/4" and put it all back together. It works great now, even after a couple of uses. If the spring starts to compress back down in the future I'll order a stiffer one from McMaster Carr. My gun is a Chicago Electric one but I'm pretty sure this would be the same in the Caswell gun as well. It just doesn't have enough umph to push the trigger back out. Hope that helps.
