Thread: Gun cleaning
  #10 (permalink)
Old 10-21-2006, 10:28 AM
Banditperformance Banditperformance is offline
Default Re: Gun cleaning
A spray bottle with water is handy for cleaning up after the day's use. Also, Acetone will melt and disolve uncured powder real easy. I use water or Acetone to clean my powder cups after the days work, and spray mu gun thourally inside and out with water(with the power off) I don't spray inside the trigger, just the outside, and inside the powder delivery section. It's a good idea to do it at the end of the day, so you sure it will have time to dry before the next time you use it. I am currently trying to rig up a high voltage plug I can use on my gun, so I can remove it form the Pwr supply and take to the sink. Much easier to clean and store then.
Dan Pesonen
Forest Grove, BC Canada
Personal motto:
