Old 10-23-2006, 10:19 PM
acidrain acidrain is offline
Default Re: Neewbie Problem HELP!!!!!!!!!!!!!
OK, a couple things... I calc'ed out your amperage requirements, and at 6 amps per sq. ft. (a good CD), you should ano for 120 minutes at .52amps to build 1mil. I don't know if you typed in wrong, or what, but you will not be able to build more than 1mil with typeII ano. Also, if you are going black, you definately want to build 1mil. For all other colors, .75mil should be good.
The wire connection is critical. DO NOT USE STEEL OF ANY SORT IN YOUR TANK. You may have ruined the acid. I would replace it just to be sure. Did you use the 1:3 battery acid/water ratio?
You need to use only aluminum as a connecting wire (or titanium). Bend the wire into a V, and wedge it in a hole, or twist it around an outside source. If you have to thread it into something, use aluminum bolts, or make your own by threading a rod.
Titanium wire works way better than aluminum, and is re-usable (aluminum is not).
Dang... Sswee beat me to it.
