Old 10-25-2006, 10:14 AM
bzer1 bzer1 is offline
Default Re: Powder Coating Inside of Rim???????
This varies between shops. Some guys will mask them because certain wheel designs will leak if the seal isn't perfect. In other cases you should make sure you get enough powder on the bead to prevent corrosion of the bead which will cause a leak. For the most part I like to cover at least the bead, and like Bandit said nobody is even gonna see the overspray so the rest doesn't matter.
