30 to 50 KV Gun Adjustments?
When I first start out, with the gun, very little powder comes out, if I shake the gun, way too much comes out (it is consistent once the heavy output starts)??
I have a mini regulator on the gun set to 10 PSI (also the moisture separator).
Powder does not seem to stick, well, to the object being coated. The ground clip is attached directly to the object and the contact is clean.
Help.
