I think the problem is when you sandblast a part you increase the surface area from that of a polished surface. I have found that I have to almost double the time I calculate when my parts are blasted. I have also found that keeping the temp. between 65 and 75 is very important. As you get into parts with larger surface areas the temp,power supply etc, become more critical.
