Old 11-14-2006, 08:07 AM
mcaswell's Avatar
mcaswell mcaswell is offline
Caswell Inc Founder
Default Re: Copy Chrome questions
It really depends whether you were immersion plating, or not.
If you were brush plating, the rate of plating will depend on the speed you move the wand around, and the total area you try to do in one job.
The actual power supplied to the wand from the adapter is approx 1/3rd amp, and as the required immersion time is 1 amp per 16 sq ", you should plate, in theory, 5 sq" with the power going to the wand. However, the surface area of the wand, if it is kept still, is about 1/2 sq", so there is much more power going to that small area. This makes the wand plate much thicker and faster. How much is difficult to determine, because the wand is not stationary.
You will see this if you keep the wand still, you'll see it will burn the area because of the excess current.
Brush plating is a rather primitive method of plating, but if used correctly is ideal for these smaller areas. The downside is it needs a little practice to find out what will work for you.
When immersion plating using PNP, you need to consider that the power supply is putting out a constant 300ma - 1/3 amp and will plate about 5 sq" with most solutions. If your part is only 1 sq" you need to place something else in with it to make up the surface area to 5 sq". It will then plate at 1 thousandth of an inch per hour.
Have A Web Site?
