Engine Block/Cam bearings??
OK, Just need a confirmation from peeps who have done blocks before. Before or after instalation of cam bearing's? Typical pushrod V8. Will the bnearings handle the heat? I know ball bearings/rollers are a no go, like in a bike engine. But you PC a block after machining is done, and cam bearing instalation is done then too, usually.
Thx for the help
