Re: How do I calculate the voltage needed to plate with zinc?
Would it make sense to just put more parts in the bath to increase the load and get a reading I can actu
\ally work with?
I'll try adding the resistor as well. I assume I'll need a 1ohm resistor that can support the maximum amperage the unit supports? In this case, we're talking about a 25amp continuous unit with a peak output of 30amps.
