Re: How do I calculate the voltage needed to plate with zinc?
Adam:
You can't go wrong with a quality unit like the Lambda (or HP, or many of the other brands that seller had). That was going to be my recommendation, not the other "PEPE" unit.
The only other thing I would have looked for is a switchable meter, so you could read low current more accurately. But as long as you're using 1 amp or more, the Lambda meter will be fine.
You're on the right track now!
Sean
