Re: Another Fridge/retrofit
Hacked it out with a screwdriver. Once you crack it you can grab it and rip it out. The foam insulation under it isn't fireproof so it has to go. That took a lot of time. I used a air chisel with a flat blade welded to it to do that. Wear proper respiration mask as you don't want to be breathing that ****. It also gets into everything.
Have fun.
Ken
