  #26 (permalink)
Old 12-03-2006, 02:33 AM
Hobweld Hobweld is offline
Hobweld is on a distinguished road
Default Re: Another Fridge/retrofit
Added a cam action latch.
Both elements were used, placed in the bottom. They work fine since the original oven was a self cleaning oven. The original control can handle running both off the same circuit.
Wiring this was a breeze. Simply mark wires as you remove them from the donor oven. I opened the control panel and removed the wires going to the top burners since they were not needed. I saved the broil circuit just taped them off and stuffed them back int he panel. If it is ever needed it is there. Wired the light and fan off same "light" switch on front panel. Easy to do. Basic electricity. Wire both elements in parallel and your ready to plug it in and test it out. That is about it.
Any questions give a shout.
Ken
