Old 12-03-2006, 01:13 PM
ashcroft01's Avatar
ashcroft01 ashcroft01 is offline
ashcroft01 is on a distinguished road
Default Re: Cerrotru and Silver Pewter
Hello,
I am in the process of restoring and re-plating several antique pieces of a serving set made of Britannia Metal which is very similar to Pewter in composition. As far as the other metal you mentioned, I have not heard of it before, but imagine it to be fairly similar.
My process is...
Clean and buff item.
Degrease.
Inspect for corrosion in pits (Pewter does pit similar to pot metal)
Bead blast corrosion if found.
Rinse.
Activate in Pickle #4.
Rinse.
Flash Copper.
Rinse.
Acid Copper (for filling and building)
Sand, Buff and Polish.
Acid Copper again if required.
Buff and Polish.
Degrease and rinse again.
Inspect.
etc. and so on if needed.
Final plate with Silver, Brass, Nickel, Copy Chrome etc.
This has worked thus far for me.
Best of luck and let me know if you have any other questions.
Curtis
