Old 12-16-2006, 10:10 AM
ashcroft01's Avatar
ashcroft01 ashcroft01 is offline
ashcroft01 is on a distinguished road
Default Re: Agitation pump, what are you using?
MrPontiac,
All of my kits came with the BOYU pumps supplied by Caswell. They do not have the option to shoot downward, but you can rotate the head slightly to shoot left or right.
You can do a Google Search for aquarium Filters and maybe pick one that is better suited to your needs or particular set-up. Just look for submersible filters. They will range in size anywhere from the mini’s for less than 3 gallon set-ups all the way up to the huge 100 plus gallon systems.
I hope that this info has helped.
Best of luck,
Curtis
Curtis Ashcroft
M and C's Plating & Powder Services
