general newbie advice
Hello
I am in the UK but I can order from Caswell UK with no problem. A general enquiry - which is the best kit to go for if I wanted to electroplate chassis parts. Nickel plating or galvanised etc. I am thinking about the effects of road salt and the weather so I would be more keen to know what is likely to last longer and resist the dreaded rust.
Also do I need to consider the effects of electroplating with regard to the strength of the steel - is it weakened at all.
Thanks very much
