Paache gun
The double headed gun sold on the silvachrome page. It is great because it is a perfect atomizer and is completely adjustable even though its single action. Also being able to control your work while spraying is a huge plus.
I have added a new tip.
21. If the surface you are working with does not wet, then clean it with windex. The amonia in the glass cleaner with help the surface to sheet the acid in the sensitizer. Use a clean cloth and windex the part down well, Then wash it with high flow DI water. Then sensitize. If it still doesnt wet, increase the concetration of sensitizer up to 4 times the amount. Do it gradually.
