Old 12-20-2006, 02:08 AM
ms042180's Avatar
ms042180 ms042180 is offline
ms042180 is on a distinguished road
Talking Zinc Plug N Plate Dark Streaks/Coverage Capacity Questions
Hello, I have two questions about the Zinc Plug N Plate kit and can't seem to find any answers to my questions.
First question: I bought a Plug N Plate kit for Zinc and my plating turned out great at first (my first batch and using about 1 flid ounce of solution) but then seemed to develop dark streaks after about 3 minutes, which rubbed off and revealed a successful Zinc plating underneath. I'm plating the ends of steel electrical conduit tube to protect the ends of the tube after cutting, which I have turning on a bed of casters which I use for all my finishing work. I have the clip end brushing the tube while the applicator brush applies the solution. Prep: I sanded down the ends of the tube with 100 grit sand paper (aluminum oxide?) to round off the edges to a nice "spun metal" look, then wiped the area clean both inside and out with a damp paper towel (clean tap water) then immediately plated afterwards. The outside of the tube is galvanized plated from the steel manufacturer and is coated on the inside with grey primer which doesn't rub off. The dark streaks don't appear to be hindering the plating, but just seems like smut similar to the silver plating process.
My second question is: How many square feet can the Zinc Plug N Plate kit cover with about .0005 zinc plate and how long does it take to apply (hypothetically speaking if I were to rub in the same spot about the size of a dime for a period of time)? I looked in the technical support section and found estimated coverage, but it had all the other metals except zinc. How do I know when it's "out" and how do I replenish it (like in the larger kits), or do I buy another 8oz bottle of solution?
Sorry for so many questions, I've looked for hours and can't seem to find the answers I'm looking for.
Thank You for your time and thanks in advance for your responses.
--Mike--
