Re: Zinc Plug N Plate Dark Streaks/Coverage Capacity Questions
The zinc solution will cover approx 2-3 sq ft. Immersion plating to 0.0005" would take approx 10 minutes, so expect the same, theorectically, for brush plating the exact same area with the wand.
Also, the wand in the zinc kit will wear away. When the zinc strip in the wand is gone, it's time to buy a new one.
You can't replenish Plug N Plate solutions. You'll need to buy a new bottle when it's all used up.
