Originally Posted by jtagger19
they are both transparent colors
you will always see the metal below if you don't use a base coat
you'll need to coat with a chrome base first and then top it with gold or brass
to make it look more like cadmuin or zinc palting I would use a silver base instead of chrome
Is there a Caswell power (part number) silver, you would recommend? Sounds like you have done this before. Any hints on the double coating. I have the Red Line Alpha gun. (great gun by the way)
