Re: Contactor and Thermostat
You got it dude... just run the coil circuit from one side of your 220v oven feed. Run the hot through the thermostat (like a light switch) and then to the coil and run the neutral straight to the coil on the contactor. The thermostat tells the coil when to energize to complete the 220v circuit to the elements and vise versa. I talk to much, later.....
