Old 12-28-2006, 09:24 PM
ashcroft01's Avatar
ashcroft01 ashcroft01 is offline
ashcroft01 is on a distinguished road
Default Re: Silver Plating Over Gold Electrodes
ealonas,
Not exactly sure of what you mean by three electrode set without a photo of it, but I am picturing in my head what I think that it would look like.
You are speaking of plating onto a printed circuit card, correct?
Are all three electrodes conductive with each other or are they electronically isolated?
There may be a small electrical charge in the card itself from any installed devices (capacitors, diodes, etc.) that may cause a bleed off of stray voltage to the electrodes allowing all three of them to plate when immersed.
When immersion plating, everything that is conductive with the cathode will get plated just the same.
The best method of achieving a single electrode plating would be to brush plate just the one that you would like silvered. This will keep it isolated from the other two if you make the connection close to where you will terminate the electro-plate.
If the wand and bandage set up is too wide or large, then try one of the pen plating wands.
I hope that this information was helpful.
Best of luck,
Curtis Ashcroft
M and C's Plating & Powder Services
