  #18 (permalink)
Old 12-30-2006, 03:50 PM
mikekozura's Avatar
mikekozura mikekozura is offline
mikekozura is on a distinguished road
Default Re: Contactor and Thermostat
Originally Posted by itsallgood
What gauge of wire did you guys use that runs to the elements?
example:
14awg = 15amp
12awg = 20amp
10awg = 30amp
8awg = I can't remember(more than 30amp)
3300watt*220v = 15amp so if you would run a separate set of wires to each element you would only need 14awg. But like my old Voc-tech teacher told me over wire and under fuse and you'll never have to sleep with your boots on. I wired my four elements two and two so I ran two sets of 8awg (four wires) only need 10awg but over wired to 8awg. If you use the contactor from Gary's site you have lots of room for wires on the load side.
Keep the wires out of the heat
Hope this helps Happy New year.
