Old 12-31-2006, 08:07 PM
skooterbum skooterbum is offline
skooterbum is on a distinguished road
Default Re: so i have a problem
i would look for something other than the ground to be your problem. the ground is needed to draw the powder to your part. you can coat without the ground you just waste a lot of powder doing it. i do not think it would have any affect on the performance of the coating. under cured and or metal prep sounds like the culprit to me. read through the forum i think you will find the answer to your problem. hope this helps and good luck.
ron
