Re: Here she be... New Oven w/pics
After using a few times it works real well. I would recommend a sealer applied with a caulking gun. Where I spread the furnace cement on flat metal ( I applied it with a spatula) it has nothing to adhere to and will fall off. In the seams it's fine. It takes closer to 30 minutes for 400, but then no problem. The double walled cabinet posed a couple problems insulating the front. I might build a open sided box for the inside for the fan to move all the air sideways, other than that works like a charm. The oven light works so I can used the dial to get an approx. temp (turn it lower when it clicks off i know the range) and the clock and timer functions work. So far so good...
