Old 06-13-2003, 11:31 AM
ard3 ard3 is offline
ard3
Default Using Battery to Anodize
if you use a car battery to power the anodizing, is it necessary to use some kind of resistance to limit the current? possibly an adjustable resistance in order to control the current, if so how many ohms are we talking?
if the circuit consists of
car battery---alum wire---part---acid solution---cathode---alum wire---back to battery
will that generate an overwhelming amount of current? or does the sulfuric acid solution provide enough resistance
