Old 01-16-2007, 06:20 PM
ashcroft01's Avatar
ashcroft01 ashcroft01 is offline
ashcroft01 is on a distinguished road
Default Re: can you polish copy chrome??
Dan,
Copy Chrome will plate onto Silvaspray and can be buffed and polished normally either by hand or with light pressure on a wheel. Just make sure that your plating thickness is adequate for any machine polishing.
I wouldn't recommend sanding or polishing the Silvaspray directly as it is applied very thin.
To achieve the best results (highly polished Chrome like appearance), you may consider a Copper plate over the Silvespray first, then buff and polish that to the desired luster before going to the Copy Chrome.
Copy Chrome is a considerably harder metal and would take a bit more pressure on the wheel than the Copper would.
Curtis Ashcroft
M and C's Plating & Powder Services
