nickel on brass
I'm having all kinds of problems getting nickel to stick on brass.
I polished the brass with Caswell buffing compounds, cleaned them off real well with acetone. Plated with a rectifier set at 5V.
Of the 3 parts I was working on, 1 seemed to take the plating fairly well in most spots. There was a couple areas that just didn't seem to take any nickel, even after repeated cleanings with acetone. The other 2 parts didn't take nickel at all I don't think.
I then plated with rhodium from a competitor. Seemed to plate ok until I used Simichrome to clean things up. The plating didn't last more than 3 strokes with a rag before it was almost totally gone. The spots that seemed to plate on the 1 part survived much better.
The brass is all from the same bar of 260 brass, polished at the same time (night before I plated them) using the same process.
I have used the nickel on plain steel and it worked, but have not had success with it on either stainless or brass.
Any suggestions?
Thanks
Scott
