Originally Posted by RNMHRD
Well , i picked up a empty steel 55-gal drum & started filling it 5-gallons at a time with paint gun cleaner AKA "Naked gun cleaner". The stuff rocks !!! will strip down a powdercoated wheel to bare aluminum in about 20-30 minutes.
One suggestion , use a good mask and good gloves when using it. Very bad for you..lol
I usually used the "aircraft" stripper, works good but the gun claener cut down on my stripping labor time by 75% !!
thanks , TIM
This works better then aircraft stripper>
? Or no?
Does it work in the cold?
