Old 01-15-2007, 04:57 PM
kcdonahue kcdonahue is offline
kcdonahue is on a distinguished road
Default Re: Newbie oven questions (electrical)
Mike,
The compressor is wired up like you mentioned black and white wire to each tab on the 20A breaker and the bare ground to the ground bar in the breaker panel (which then connects to the ground tab on the receptacle). I wired this up a few years ago and the wire is what was recommended at the time.
Do you gentlemen feel I should upgrade my wiring? The 20 amp receptacle doesn’t have a provision for a Neutral wire, just a green ground screw.
Thanks for the help and comments!
KC
